2001 v70 bulb replacement
Old Mar 30, 2011 | 05:59 PM
sellmyvolvo's Avatar
Default 2001 v70 bulb replacement
Driver side inner bulb unscrewed cap, bulb was blown and fused together(inside the glass)
replaced with new-nothing- checked leads no power.
is there a fuse? do those wires come from the passenger side? would the wires burn up somewhere?
Thanks!
Old Apr 2, 2011 | 12:35 AM
checksix's Avatar
It would help if you were more specific. I'll make the assumptions you are talking the high beam bulb. right? The head light switch can determine if the high beams even work. In one setting, the allow you to only "flash" the highs, but they won't stay. Another setting allows them to stay on. I'd suggest you start there.
Jerry
davej
Apr 22, 2011 08:47 AM
Rawlinsray
Feb 3, 2011 01:17 PM
2005s60
Jan 19, 2011 01:50 PM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
