2001 V70 Intermittent Starting Issue
Old Apr 29, 2011 | 08:42 AM
bb8840's Avatar
Default 2001 V70 Intermittent Starting Issue
A couple of weeks ago, I went to start my V70 and all I got was the clicking noise. I also noticed that something odd must have happened with the power since I received "check ABS" message and the clock had to be reset. I assumed the starter was going and replaced it. The car started fine for several days until today. I had the same problem occur. I tried several times and was finally able to start the car.
I have a fairly new battery and the terminals appear clean. Any helpful hints out there?
Old Apr 29, 2011 | 08:26 PM
Georgeandkira's Avatar
Default Load test it
Hello, "fairly new"; after the questionable circumstances you described I'd have the battery load tested before doing anything else. Kira
Old May 1, 2011 | 12:25 AM
gdog's Avatar
The clicking noise when trying to start indicates your battery is in a low state of charge; the clock resetting would be another clue toward the same conclusion.
I would suspect the low battery was caused by charging issue (alternator) rather than the starter. Like George said, ck the battery and assuming it's low, ck out the charging system...
twosheds
May 23, 2014 07:34 PM
Nirky
Jul 29, 2010 02:21 AM
adracoman@hotmail.com
Jul 27, 2010 08:18 PM
algal1
Jan 23, 2010 01:35 AM
