2001 V70 jerking when releasing accelerator, no cruise control
Old Aug 19, 2010 | 03:07 PM
stunna7516's Avatar
Default 2001 V70 jerking when releasing accelerator, no cruise control
I have a 2001 V70 and I have been experiencing some problems with it lately.
I was on a road trip using cruise control and all of the sudden, my cruise control turned off and I could not get it to turn back on. At the same time, I noticed that when I release the accelerator, no matter how slow, the car jerks/stutters. The jerking is very similar to what would happen if you released the clutch (the car is manual) without giving the car enough gas. This problem stuck with me for a couple of weeks and then both problems went away. Since then, the problem has come and gone a few times, but I think eventually I will have to do something about it.
Any ideas? Someone thought I might need new spark plugs, but I want to have some idea if it is something more serious before I take it in for service. I also have a factory recall advisory regarding my fuel pump if that could be the cause. Thanks!
Old Aug 22, 2010 | 11:15 PM
FujativeOCR's Avatar
I'm troubleshooting something similar on my '01 V70 XC right now. The Cruise Control problem I've had intermittently since I've owned the car...a year. But the hesitation/bouncing of rpms as I let off the throttle is a recent development.
Of some significance however, is that I just got new plugs on mine a few months ago, after a coil pack went out. So it may be safe to rule those out of your list.
I was also getting a Engine System Service Required with a Code 44. That was a Transmission Speed/Heat sensor. Got that replaced, and no more code, but it still surges/hesitates. I think they are two different problems.
I tried cleaning the MAF and put a new air filter in. That didn't help.
Tomorrow afternoon I'm going to try a new Fuel Filter and see what's up.
Old Aug 23, 2010 | 04:27 PM
stunna7516's Avatar
While your problems sound similar, the strange thing is yours don't sound linked and mine definitely are. Whenever the surging problem occurs, I can't turn on my CC. Whenever the problem is gone, my CC works fine.
Either way, I have an appointment with the dealership tomorrow to check out my fuel pump, so maybe I can get some hints about my other problem at the same time. I'll report back later this week to let you know what they say.
Old Aug 23, 2010 | 07:07 PM
Georgeandkira's Avatar
Default Wild Guesses
Hello, Motor mounts? Doesn't jibe with the cruise control symptom, I know.
Vacuum leak-rough running and some sensor disengages the cruise control? Kira
Old Aug 16, 2017 | 02:00 AM
kola's Avatar
Unhappy 2001 s60
I have a manual 2001 S60 with the exact same problem.
when the CC works, its 100% smooth.
when the CC doesnt work, car jerks when releasing the throttle and I can hear a loud metal ish sound, I'm guessing the weird sound comes from the transmission.
Car also uses about 1L of oil for every 1 000km i drive(no leaks, comes out the exhaust), not sure if that is related to this problem. But thought I should mention it.
wifes-s80
Jan 5, 2010 06:52 PM
H20Gguy
Aug 15, 2009 12:15 PM
Robnxious
Mar 10, 2009 12:07 AM
csx3691989
Nov 20, 2008 05:32 PM
danrashba
May 14, 2006 01:55 PM
