2001 V70 T5 - Power Locks Pop-Up
I have a 2001 V70-T5 that has a continuous power lock problem. It was fixed twice while under warranty and it has started again.
If you use the remote, the locks will go down in the lock position and then after about 10 seconds the driver side lock will pop up in the unlock position.
If I use the key to lock the car there are no problems. I have tried using different remotes and still the same problem.
Any advice on how to fix the problem would be greatly appreciated. I would like to do it myself.
Thanks,
gigrichj
Thanks,
gigrichj
mrbaja
12-17-2005 03:41 AM
