98 V70 Front Right Strut or clanking noise
Old Mar 28, 2007 | 10:41 PM
chevolvo's Avatar
Default 98 V70 Front Right Strut or clanking noise
Hello all.
98 v70 turbo 2wd.
loud front pass side noise when I hit bumps. sounds like when your control arm bushing has dissapeared or when someone changed the strut and forgot to tight the strut top plate to the car all the way.
This is a metal to metal type of clanking sound.
I checked all bushings and sway bar ened links and all is good. I think the problem is the strut bearing (located at the top of the strut assembly)
the front struts were replaced 3 years ago but im sure they only changed the strut cartridge not the whole deal.
This is just an educated guess so if anyone has any different experience please let me know.
Anything to watch for when taking the front struts off this car?
Thanks
Old Apr 2, 2007 | 02:06 AM
nrandy58's Avatar
Default RE: 98 V70 Front Right Strut or clanking noise
It's most likely your stabilizer/sway barlink. I just had my drivers side 2000 V70 link replaced. I had the same symptons you describe...in fact I too though it was the strut bushing/mount. Apparently the links are prone to getting week and start clanking like it was a strut problem. The good think is replacing trhe link is a lot easier and less costly than removing the strut assembly. The link cost me $40.00...clunking is gone.
Hope this helps.
,Randy
Old Dec 21, 2008 | 02:37 AM
dc.shinji's Avatar
Hello. I'm getting the same "clunk-clunk" noise in both sides of the sway bar links. I saw that they have two little ball joints with plastic caps behind them. Are they something I can tighten up by turning the caps or hammering them or do I have to replace the parts to have the problem solved? Thanks
Old Dec 21, 2008 | 06:33 AM
Replace them.
Old Dec 21, 2008 | 01:12 PM
dc.shinji's Avatar
Thanks, I just wanted to make sure I wasn't spending money in something I didn't have to. I'll order the parts right away.
Old Dec 21, 2008 | 04:13 PM
djerikd's Avatar
If replacing the swaybar links doesn't eliminate the noise, check the spring seats. If they're shot too, replace only with the heavier-duty, OEM XC90 spring seats.
Old Jul 24, 2011 | 11:08 AM
SpiderGuy44's Avatar
Default 99 v70
Hi folks! I just joined this Forum. I guess that what has been written here also applies to my 99 V70. Anybody know where I can get service manuals for this car?
Old Jul 25, 2011 | 04:48 PM
ecberr's Avatar
alldatadiy.com is an online manual subscription. it cost about $30 if i remember correctly
Old Aug 31, 2011 | 12:56 AM
tjgreen's Avatar
Default 1999 V70 same problem
I have the same front left clunking when driving over bumps.
What steps will I take to determine the problem and then what parts should I try to replace first / order off eBay?
(I'll see if the top bolts are turning freely tonight)
chef
Apr 14, 2010 06:15 PM
trosaire
Aug 19, 2009 08:05 PM
saylor
Jul 26, 2008 09:45 AM
saucmik
Jan 14, 2008 06:28 PM
