Brake Booster Question
Old Aug 6, 2008 | 09:11 PM
shop2's Avatar
Default Brake Booster Question
I replace the brake booster with a used one matched to my car (2002 V70 with DSC) the used booster came with a pedal position sensor but the plug would not fit the sensor. The used sensor has a two blade connector and the original sensor has a three pin connector. I replaced the used sensor with the originalsensor. The only difference between the two besides the connection was the length of the "probe". The used one was shorter than the original one. There are no console mesages and the brakes work great, no more hissing. Is this going to be an issue with the DSC or any other functions. The only remedy I can see would be to purchase a new plug and modify the wiring to accept it.
Any thoughts?
Old Aug 8, 2008 | 06:37 PM
Default RE: Brake Booster Question
It shouldn't be an issue. I have never tried but should be fine.
Old Jul 29, 2012 | 05:31 AM
robk's Avatar
Can anyone give me advice on how to change the brake pedal position sensor? I damaged mine while installing the brake booster.
I see there is a metal retaining ring. How do you get it out without damaging the surrounding plastic?
sasjzl
Jun 11, 2013 11:21 AM
the_brain3000
Nov 5, 2011 07:06 PM
Nataku
Mar 7, 2011 06:59 PM
snpklinefelter
Dec 22, 2009 06:26 AM
frontsight
Apr 16, 2006 04:35 AM
