Brake problems
Brake problems
I have an 02 V70 and just replaced the front rotors and pads. The brakes before this were vibrating pretty bad when braking. Although it is much better than it was it still viibrates pretty bad when braking. I made sure the hub mounting surfaces were very cleaning when I bolted on the new rotors. Could it be the rears or could there still be an issue with the fronts? Never had a car before with rear discs. From my experience the front usually cause this problem.
Jomo1994z71
01-28-2008 09:05 PM
