Can't get the new alernator to fit! Please help!
Hello everyone. I have a 2001 Volvo V70 non-turbo. I'm trying to replace the alternator and have been using this website to help me along the way. I've run into a roadblock.
I successfully removed the belt, PS pump (not all the way, but moved it to the side), and the old alternator.
I have the new alternator in the right spot, but it doesn't seem to want to slide into the area that it should. There is a gap and 2 bolts that go through it, and the alternator is supposed to slide into the gap, but it won't go.
Any suggestions on what I should do would be much appreciated.
-the dude
-the dude
I found this on a different message board.
http://img413.imageshack.us/img413/3...0belts2xp0.jpg
I know it's not the same car, but if you look at the #4 bolt. The part of the alternator that that goes through is where I am having problems. Do I have to remove/loosen whatever is below it? Is that the AC?
87 740 turbo wagon
02-20-2014 08:50 PM
bimmerd00d
03-18-2009 06:55 PM
yklin_tux
03-02-2008 03:43 PM
