Clunking noise over potholes..
Old Apr 21, 2009 | 10:15 AM
GMad's Avatar
Default Clunking noise over potholes..
I have a pretty severe clunking noise when driving over potholes and drain covers, so I had a look at the offending side.
The top mount/bearing has a heck of alot of play in it, so replacement is on the cards.
My question is, is it likely to be the bearing, the rubber top hat or both that are bad?
Old Apr 21, 2009 | 06:27 PM
01_fast_ride's Avatar
If the strut nut springs back after turning it, the spring rubber still good. If you can turn the nut and it stays, the spring rubber is bad. That can make the clunking sound. I am not sure if the bearing plate will make the same sound, if any, once it goes bad. Take a look at the sway bar end links too. If they have play they can knock.
Old May 10, 2009 | 04:41 PM
GMad's Avatar
The rubber was goosed!!
Replacement was cheap and easy and now my car doesn't make a noise..Reeeesult.
Old May 11, 2009 | 05:06 PM
mcleantmw's Avatar
Which part making the noise did you replace..........not sure from your description........the upper motor mount?
Old May 11, 2009 | 07:41 PM
GMad's Avatar
No, the upper front spring mount. The centre of it, the bit that the threaded part of the strut passes through, had become completely detached.
tommyjumbo
Apr 28, 2008 04:11 AM
leebae
Mar 26, 2008 06:59 PM
ice queen
Jan 16, 2008 02:58 PM
m1964
Feb 3, 2006 12:32 AM
Red XC
Suspension
Oct 22, 2005 11:58 AM
