Cold Weather causing "Door Open" warning
Old Jan 20, 2026 | 01:38 PM
bblooz's Avatar
Question Cold Weather causing "Door Open" warning
It's colder than ever here in Michigan lately, and our '09 V70 (P3) thinks that the driver's side rear passenger door is open. The latch still works, and the door is closed, but I assume whatever sensing switch mechanism must have some frozen moisture preventing a correct status reporting to the central computer. I don't see anything obvious in the door frame near the latch, but short of pulling the door card off to spray the sticky switch, where can I spray it down with some WD-40?
Old Feb 28, 2026 | 03:42 AM
dhsyu's Avatar
My DIC displayed "Door Open" while I was driving to work today, and my interior lights started to come on as if I had opened the door with the engine running. I was traveling roughly 70 mph around a small right-hand bend. I simply pulled on the door a little bit, and it vanished without releasing anything.
192.168.100.1 192.168.1.1
NancyB
Oct 14, 2015 08:18 AM
schumicat
Oct 11, 2013 11:00 PM
TrouperL
Nov 21, 2011 11:08 AM
jilcomes
Jan 27, 2011 05:42 PM
tanjung66
Oct 26, 2007 07:39 PM
