Cruise control - any help?
Old Jun 20, 2009 | 10:08 PM
Blartwagen's Avatar
Cool Cruise control - any help?
Hi, I seem to have a non existant cruise control function. No indication that its on or off, it does nothing. I live quite remotely in Ireland and mechanics kinda suck air at the mention of such things. So I have the cruise control gear, but no light comes on when I press the switch, and there is no effect on the car whatsoever. Does anybody have any ideas where I should start looking to solve this problem? Any help would be much appreciated, then I can go looking for a straight road.....
Old Jun 21, 2009 | 09:39 AM
The cruise vacuum pump is mounted under the battery tray. Check the hoses coming off of the cruise pump to the cabin.
Old Sep 6, 2009 | 09:08 PM
mgambuzza's Avatar
I was wondering if it may be the start of an ETM failure (if you have 99-01 V70). Mine started by the Cruise failing, then the engine stuttering began. I am now told it is the ETM. Hopefully this is not the case with you and it may be a simple vacuum or component issue.
Old Sep 9, 2009 | 09:19 PM
checksix's Avatar
My cruise failed when my ABS went out.
Jerry
Old Feb 15, 2010 | 09:42 PM
mgambuzza's Avatar
This was a failed ETM(replaced Oct 2009). Once replaced and reprogrammed, throttle response returned, and the cruise functioned once again! Excellent results since (4k miles later).
Volvo-Finn
Mar 20, 2011 02:47 AM
ZephLeggett
Mar 28, 2010 10:43 AM
rspi
Mar 7, 2010 06:13 PM
H20Gguy
Nov 11, 2008 08:44 AM
jfikentscher
May 31, 2006 09:58 PM
