Driver Side door /window console electrical problem!
Old Aug 20, 2009 | 08:09 AM
Ovlov NB's Avatar
Default Driver Side door /window console electrical problem!
Own a 2001 V70XC that has an intermittant problems with the drivers side master control console, (window, mirrors, control override, locks). The problem is that the control module does work all the time. It clicks for about 5 minutes (shorting out?) rendering it useless. Eventually this stops and then the control panel works fine... While the drivers control is not functional (clicking/shorting?), the other door control consoles work fine. Any idea on the problem and a low cost fix.
I've had the door apart and have dissambled the driver door control console module -> did not see any signs of a short.
Ovlov NB
Old Aug 20, 2009 | 06:21 PM
The module is usually bad when that happens.
Old Aug 21, 2009 | 07:31 AM
djjohno's Avatar
I have the same proplem. If I find a replacemet module, is it just a plug it in and your done or is there computer reprogramming that needs to be done?
Old Aug 21, 2009 | 06:51 PM
Some people have installed used ones and they worked. But you are supposed to get a new one and have it programmed to your car.
Newport_j
Oct 18, 2014 03:55 PM
cshields
May 23, 2010 01:13 PM
hosey82
Aug 5, 2007 06:59 PM
charlesbattaglia
Jan 19, 2006 11:09 PM
florida98s70glt
Mar 20, 2005 01:04 PM
