engine management light
Old Dec 15, 2005 | 05:30 PM
flyer1's Avatar
Default engine management light
thinking of buying a volvo v70 20v turbo , only problem is the guy says the engine management ligh thas come on he says the car is stil l running fine ,should i be warey of this or is it a common fault thanks any info
Old Dec 16, 2005 | 08:59 PM
Default RE: engine management light
It could be as simple as a loose gas cap or as major as a bad turbo or something like that.
Make him take and have the codes pulled so you know what is going on.
Old Dec 17, 2005 | 02:10 PM
flyer1's Avatar
thanks for that he reckons he just started it up the other morning and it cameon and wont go out cheers again, i was reading another post and it says if u dsconect the bat and leave hen reconect it should go out is this true
Old Dec 17, 2005 | 04:34 PM
It might work and it might not work. Depends on the code.
Old Dec 19, 2005 | 04:51 PM
flyer1's Avatar
decieded not to buy now . just bought a v70 20 valve awd, thanks for the help tech sure i will need some more advise sooner than later
Old Jan 5, 2006 | 12:14 PM
S70driver's Avatar
What year V70? Watch for the ETS (Electronic Throttle System) if it is a 1999.
karls_dad
2001-2013 model year V70
Oct 31, 2013 01:38 PM
Bam Bam
Aug 13, 2013 10:01 AM
scottishbloke
Jan 31, 2007 08:50 PM
HelgaTheS80
Jan 15, 2007 12:27 AM
s80driver
Oct 18, 2005 09:19 PM
