front caliper fitting issue
Old Apr 12, 2009 | 12:14 PM
Clash1977's Avatar
Default front caliper fitting issue
Just attempting to reinstall new FL caliper and pads. Before bolting it all back in I noticed there isn't enough clearance to fit rotor between pads and caliper. Compared old parts and they look identical. Might I need to press in the piston on a new caliper still?
Thanks
Mike
Old Apr 12, 2009 | 01:38 PM
Johnny Mullet's Avatar
If the pistons will go in more, then compress them. Are the pads correct?
Old Apr 12, 2009 | 05:18 PM
JTapper's Avatar
Noticed you said FL in your post. Did you mean Front Left? Are you also replacing Front Right? You must do both sides at the same time, if you don't it could be a very serious safety issue. Just thought I would mention that.
Old Apr 13, 2009 | 06:43 AM
Clash1977's Avatar
Figured it out...had the pads reversed...not paying attention to things when I remove them usually gets me into trouble as it did.
The other caliper seems fine...I will likely remove and grease the sliders and swap pads in the next few days. Should I replace calipers in pairs as well?
Old Apr 13, 2009 | 06:47 AM
You do not need to replace calipers in pairs, but it never hurts. Doing them in pairs supposedly makes for "even braking", but if that was the case, then the hoses should also be replaced in pairs. I never had a problem replacing just one caliper.
Old Apr 13, 2009 | 03:17 PM
JTapper's Avatar
Sorry, should have been more clear. I meant to say pads in pairs. Calipers in pairs wouldn't hurt if you were high mileage since if one failed after high mileage, the second could be due as well.
BigGreenGragon
Sep 26, 2010 03:21 PM
s60ag
Jun 4, 2010 07:21 AM
holobox
Oct 15, 2009 07:03 PM
Kaspir
Mar 23, 2008 12:01 PM
silverado102002
Jun 19, 2007 09:11 AM
