Has anyone swapped their VC unit with Haldex?
Old Feb 5, 2023 | 05:41 AM
Adi.mun's Avatar
Default Has anyone swapped their VC unit with Haldex?
I have a 2001 V70XC with 2.4t. I love the car, I got it with all the options I wanted but the awd is on it's way out since it's a VC and for some reason the diff was ran without oil for I don't know how long before I got it. I want to drop in the haldex unit. Has anyone done this swap before?
Old Feb 5, 2023 | 11:03 AM
You won't be able to do it. The haldex system is integrated with the ABS system.
Actually, certainly with enough money you could, but it would be cheaper to purchase a 2003+ car that came with Haldex.
Old Feb 7, 2023 | 08:28 AM
Adi.mun's Avatar
Wouldn't that just be a programming issue? Mechanically I know the pieces just bolt straight up and the DEM of the Haldex plugs into the REM. Wouldn't it be just a bit of wiring and telling the ecu 'Hey, send this data and this data on these two pins.'?
Old Feb 7, 2023 | 08:54 AM
OK i'll bite - who is going to do this "programming"?
I'd bet the ABS/DSTC module does not have the brains to control the haldex. So perhaps figure out how to rig a 2003 ABS module onto a 2001. Then you might need a wiring harness - and does the CEM need to know about this new module?
Old Feb 7, 2023 | 09:35 AM
Adi.mun's Avatar
Since I currently ended up living in the Netherlands for a while volvo tuning support is at each and every corner so I'll rely on my local tuner. I've yet to bring all this up to him since I want to do my ground work before.
Huh, yea, I guess so. If they managed to retrofit a 2003 rem and make it play nice with my 2001 CEM then I guess replacing the ABS module with a DSTC one shouldn't be that much of task. Hopefully.
​​​​​​Man, I would get a 2003+ but I got a stellar deal on the car I have and to trade this one in I'd also have to add between 2500 and 3000 euros on top of it. AND I have the 2.4 which is in immaculate condition and I've had it tuned to 260 bhp on stock everything almost.
Thanks a lot for mentioning the DSTC. Would there be anything else that I'm missing for this swap?
SparkyNZ
Aug 12, 2022 11:08 PM
Jbweld
Apr 9, 2018 01:15 PM
Bennie
Sep 9, 2012 03:09 PM
Pittman
Jul 12, 2010 02:39 PM
vmaisuria
Oct 11, 2009 07:52 PM
