I can't figure out which steering rack I need?
Old Feb 15, 2010 | 10:03 AM
halcyon419's Avatar
Exclamation I can't figure out which steering rack I need?
Hi,
So my car is leaking power steering fluid like a sieve out the rack. I have an issue identifying which replacement part I need, though. The 11th digit on my VIN is a 2, however when I check for parts that go along with this VIN# it's only showing that it fits models w/ turbo or AWD. My car is FWD non-turbo yet my 11th VIN digit is 2? P.S. my car is fully-loaded except for the turbo/awd I'm not sure if that means anything, I am not sure if it's an SE model or base, never been able to get a straight answer on that. So I am confused on which part to buy. Anyone who has run across this problem please advise?
Thank you!
***edit: I also just found out that there are different racks for cars with the 11th digit VIN# as "1" determined by 2 other digits in the VIN, being 53, 56, or 61. Well, mine is 61 and again that coincides with the 11th digit being a "1" but my 11th is a "2". Makes no sense!
Old Feb 18, 2010 | 09:11 PM
On the plate under the hood should be a suspension number that you can use.
Old Feb 22, 2010 | 08:16 PM
shadetree_v70's Avatar
There's an ID plate on the D/S engine bay on the fender that says which is which. If you look at the FCP Groton for the parts they'll direct you on which numbers to pay attention to.
deeppaul
Dec 30, 2009 08:46 PM
TiggerBBSim
Apr 3, 2009 12:17 PM
tarun90
Dec 30, 2007 10:32 AM
jorhyne
Oct 20, 2007 06:31 PM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
