Installing amp best way to run wires?
Old Aug 13, 2007 | 02:59 AM
jhi979s's Avatar
Default Installing amp best way to run wires?
So I've run all the wires for my amp but I don't know the best way to get the speaker wires to the speaker the most cosmetically way possible. Any suggestions?
Old Sep 27, 2007 | 12:47 PM
cbatstone's Avatar
Default RE: Installing amp best way to run wires?
This is never easy, because if you wanted to do it perfectly you would have to run it through the small hole, and a watertight boot that goes into another hole/gasket in the door. It's the same on all cars, and the easiest way is to bypass this, running it outside of the boot though you would see it when you open the door. Sometimes I've found that your best bet is to utilize the stock speaker wiring to the dash, then just run new wires from the dash where the cd player is, all the way back again to your amplifier in the rear.
Good luck i'll be doing this soon.
Moshman1205
Mar 11, 2012 01:19 AM
baadandy
Mar 26, 2011 04:51 PM
cb1313
Aug 9, 2009 07:33 AM
kockyhardrockr
May 19, 2009 09:00 PM
randyjoy
Nov 7, 2004 08:23 PM
