Instrument panel bulbs replacement
Old Dec 29, 2007 | 05:53 AM
rowingman's Avatar
Default Instrument panel bulbs replacement
V70 2.4T 2002. How difficult is it to replace bulbs on the instrument panel?
Old Dec 29, 2007 | 06:11 AM
Default RE: Instrument panel bulbs replacement
Time consuming.
You need to remove the upper dash pad to replace them.
Old Dec 29, 2007 | 06:35 AM
rowingman's Avatar
Time is one thing, but never quite fitting everything back exactly, is my main concern(I've seen several "dashboards" that never quite looked neat and flush, once worked on). Tech what should I do? Should I have a Pro take care of it?
Old Dec 29, 2007 | 07:28 AM
JimKW's Avatar
Which ones are burnt out? I don't think I would pay a dealer to change the bulbs in the dash. I have taken the cover off my 97 850 and got it back on OK. There is a little rattle in the middle that I need to find though, but it looks fine. If you do it yourself, just be extra careful and remember some of the screws are going into plastic so just snug them up, do not over tighten. If you are not at all hand at doing stuff like this, try to find somebody who is to help out. It is the kind of thing I would trust my youngest daughter or my son to do cause they would be good at it.
Old Dec 29, 2007 | 08:03 AM
rowingman's Avatar
The one behind the clock and outside temp is out. If I attempt to change it, should I also do the other one?
Old Dec 29, 2007 | 09:46 AM
If you do one do them all.
Your is a little like the 850 I made a post about removing the dash pad to replace the bulbs check it out.
Old Dec 29, 2007 | 11:01 AM
jks2's Avatar
Hey Tech, the passenger side of the temp control light is out in my sons 850. Does it require removing the dash pad to access the control unit? I noticed in my Haynes manual for the manual temp that you can access from the front, but his has the auto temp control and when I pulled the ***** I didn't see any screws to remove.
Old Dec 29, 2007 | 12:05 PM
ORIGINAL: jks2
Pull the radio then push the climate module out from behind.
Then you will have to open it up to replace the bulb.
socal8080
May 30, 2011 05:17 PM
trooperone
Jun 20, 2010 10:45 AM
jrcochranusa
Feb 19, 2010 02:30 PM
ko_kidd
Aug 14, 2006 09:10 PM
ebrobb
Jun 22, 2006 10:46 AM
