interior ventilating fan stops
Old Jun 19, 2006 | 08:28 AM
jaymac's Avatar
Default interior ventilating fan stops
On occasion after turning the fan on it starts then stops and both lights flash on the AC buttons .It will try to restart each time you try but just stops. later in the day after restarting the car it works fine. This happened a few times in the winter just sub-0 thought it might be that. Now it has happened in the summer 70+.Garage says cant do anything if it is working when I take it in. Another garage says might be dodgy fan motor. Big bucks unlesI can have it done under warranty. Model is 1998 V70 AWD
Any help will be much appreciated
Thanks
Old Jun 19, 2006 | 09:11 PM
Default RE: interior ventilating fan stops
The Blower motor and resistor are bad.
Old Jun 20, 2006 | 09:39 AM
jaymac's Avatar
Thanks does this require a new motor or can resistors be changed I feel tht 6 months between the fault occurring seems along time for dodgy motor or have I just been lucky
Old Jun 20, 2006 | 11:51 PM
You have been lucky it will get worse.
Replace both or atleast the motor.
millwoodva
Aug 10, 2015 10:54 AM
mgreen2
Jun 7, 2009 04:29 PM
titaniumfj
Aug 7, 2007 07:22 PM
NCS60
May 9, 2007 02:00 AM
oalsa
Nov 16, 2005 10:45 PM
