intermittent starting problems V70 AWD
Old Jul 13, 2008 | 03:12 PM
mparker's Avatar
Default intermittent starting problems V70 AWD
I have intermittent starting problems with my 1999 Volvo V70 AWD 101000miles. It normally starts just fine and once running it is always absolutely perfect in performance,idling, acceleration etc. The starting problem seems unrelated to any particular conditions, the engine turns over fine but won't fire. Usually when I leave it for a few minutes and try again it will start but sometimes it needs a wait of 30 minutes or even a few hours. Eventually it always starts, without flattening the battery. I have had the car checked at two local garages, there is no fault light on the dash and no ecu fault codes logged. When it has been at the repair garage it behaves just fine so they can't diagnose the fault. The frequency of the starting problem is becoming a little worse, it is now failing every few days rather than every few weeks; it has now been going on for about 6 months. I have tried new plugs, fuel filter, thinner oil (5/30), and nothing is better. Any ideas? thanks
Old Jul 13, 2008 | 08:48 PM
Default RE: intermittent starting problems V70 AWD
Do you have a second key? It might be an immoblizer problem.
Old Jul 14, 2008 | 04:28 PM
JRL's Avatar
JRL
Could be the check valve in the fuel pump or the fuel pump relay
Old Jul 14, 2008 | 08:09 PM
NeoDavinci's Avatar
I had nearly the same problem with an 05 Altima once right after I bought it. It would typically decide to start up right after we got it off the tow truck and nothing ever came up on a computer check. About the fourth trip to the shop, a fault code came up, and it was a computer control issue. They replaced some chip or other.
You might try keeping an ODBII scanner on hand in the car and hooking it up as soon as it happens rather than waiting to get it to a garage.
Hope that helps.
Old Jul 14, 2008 | 08:13 PM
On The Volvo's it will only set and immoblizer code when it isn't starting.Thats before the ignition is shut off. If you turn it off then back on again and it starts the code is gone.
Old Jul 15, 2008 | 02:59 AM
mparker's Avatar
Thanks for the hint, I'll try the immobilizer issue first and then ask my garage to check the fuel check valve etc thanks Michael
Old Jul 15, 2008 | 03:01 AM
mparker's Avatar
thanks for the help, I'm afraid I don't have such a scanner or know really what to do with it - thanks anyway michael
Old Jul 15, 2008 | 03:04 AM
mparker's Avatar
Thank you for this info', most interesting, I didn't realise that the fault code could be wiped on a restart. Regards Michael
Old Jul 18, 2008 | 03:46 PM
mparker's Avatar
Problem solved: it was in fact the immobiliser aeriel in the ignition key switch that was faulty. My local Volvo agency plugged in a proper Volvo fault code reader and there was a code logged, they replaced the immobiliser aeriel unit and the problem appears solved. However, I won't be totally convinced until a few weeks have passed without a starting problem. Thanks everyone for your suggestions. Michael
Old Aug 31, 2008 | 06:53 AM
mparker's Avatar
I have used the car now for six weeks and have had no more starting problems with the new imobiliser tranciever unit fitted in the keyswitch, thanks everyone Michael
Old Aug 31, 2008 | 08:02 AM
Glad it is all fixed now.
tcrossley
Sep 21, 2010 07:48 PM
Nontechie
Oct 24, 2008 11:55 AM
H20Gguy
Sep 17, 2008 12:58 AM
bigb1rd
Mar 1, 2005 09:59 AM
