Key/Ignition problem
Old Nov 29, 2005 | 09:04 PM
soapmaker's Avatar
Default Key/Ignition problem
Help! The key in my V70 won't turn past position I. Any thoughts?
TIA
Old Nov 29, 2005 | 09:32 PM
Default RE: Key/Ignition problem
The steering wheel isn't locked is it?
Try playing with the shifter as well.
Old Nov 29, 2005 | 09:39 PM
soapmaker's Avatar
The steering wheel is NOT locked. I tried locking it and unlocking it just in case. I also used the shift lock override to put the car into neutral, but the key still won't move past position I.
Old Nov 29, 2005 | 09:55 PM
Sounds like the lock cylinder might have gone bad.
Here is where you should go next. Pop the top cover on the steering column off. The remove the 2 screw holding the lower cover on and remove. Then look on the back side of the ignition you should see the electrical part. Remove the 2 screws and remove the switch. Then see if the key moves then. If it does then the electrical part is bad. If it doesn't then the lock cylinder part is bad.
Once you remove the electrical part you might be able to get it started.Leave the key in the ignition and turned as far as you can. Then turn the electrical part with a screw driver and see if it starts. It should the Immoblizer should still read the key since it is still in the ignition. You are just bypassing the key turning it to start it.
Old Nov 29, 2005 | 10:03 PM
soapmaker's Avatar
I'll give it a try.
Thanks for the quick responses and thanks for your help
Old Nov 29, 2005 | 10:14 PM
Let me know how it goes.
Old Nov 29, 2005 | 11:52 PM
soapmaker's Avatar
Will do.
Old Nov 30, 2005 | 12:08 AM
ok thanks.
Old Dec 9, 2005 | 08:35 PM
soapmaker's Avatar
It was the lock cylinder. Good call.
Thanks again for your insight, and sorry it took so long for me to reply.
Old Dec 9, 2005 | 08:59 PM
No problem glad you got it fixed.
dodgerkcj
Jul 2, 2018 11:41 AM
trooperone
Oct 18, 2009 02:17 PM
pbialk
Nov 3, 2007 05:26 PM
jfikentscher
Oct 10, 2005 08:32 PM
