Left blinker failure
Old Oct 29, 2012 | 12:47 PM
Sethbbull's Avatar
Default Left blinker failure
I just bought a 2001 Volvo v70 t5 and on the way home from the dealership my indicator started blinking really fast and the bulb failure warning light came on, I replaced all the blinkers on the left side but it still blinks fast and the bulb failure light is still on, any ideas?
Old Nov 14, 2012 | 01:46 PM
Triston's Avatar
I just had that same issue with my V70 on the front driver's side turn signal. The faster flashing is because the flasher module isn't getting enough of a load to "balance" the flash rate, as compared to the other side's turn signals. I replaced the bulb and got no change. Finally, I checked all of the bulb sockets with a multi-meter, after determining that intermittent power was present with the signal lever on, that could only mean that there was a poor connection between the bulb and socket terminals. A little shot of contact cleaner and a wire brush and everything was fine again.
Hope this helps you-
Triston
zinko
2001-2013 model year V70
Jan 9, 2016 10:09 AM
Maroon240Wagon
Mar 3, 2011 10:11 AM
EEaudio08
Aug 28, 2010 02:45 PM
qstyle
Jul 16, 2010 11:15 PM
nicolaselias
Feb 28, 2008 08:23 PM
