Low beams Keep Going Out 2004 V70
Old Jul 2, 2010 | 10:02 AM
prove_17's Avatar
Default Low beams Keep Going Out 2004 V70
Hello everyone, new to the forum. I have a plain 2004 V70 wagon and the low beam lamps keep going out. I had the mechanic replace about two or three this year and I replaced the last ones with the best bulbs I could find(said HI & LOW beam bulb on package) and one only lasted about two months. I made sure not to touch the glass and put it in correctly. Any suggestions?
Old Jul 2, 2010 | 08:02 PM
gdog's Avatar
Ck the voltage at the light and report back. Vary the RPMs (trans in Park/Neutral of course) while measuring and record the highest voltage.
If highest reading is above about 14.5 - 15.5 volts then ck out the voltage regulator on the alternator.
Old Jul 3, 2010 | 05:37 AM
rowingman's Avatar
Make sure you're buying the right bulb! This happened to me a couple of times until I realized that there are two "recommended" bulbs with different amperages!
Old Jul 3, 2010 | 10:33 AM
user17600's Avatar
Default Check the connectors inside the socket
The wifes XC70 was going through low-beam bulbs (H11's) like mad (1 a month), but the funny thing is that the bulbs would work in another car just fine. Replaced the passenger bulb 4 times before I figured out the issue: one of the connectors within the socket was pushed down (probably during a bulb change) and was intermittently losing contact (usually when heated up). Took a small jewelers flat bladed screwdriver and pushed all the connectors within the socket towards the top of the socket and held them in place when I replaced the bulb and haven't had another issue in the 6 months since. Next up: converting the XC to HID as I've done on the '04, just testing the longevity of the HID kit for a few more months...
Old Jul 3, 2010 | 05:18 PM
prove_17's Avatar
You guys are GREAT! thanks for the suggestions.
Old Jul 3, 2010 | 09:15 PM
thansen's Avatar
Default Volvo
I have a volvo s60 that I am trying to change the bulb on but can't get the connector disconnected. I can pull the bulb out but not the connector-any sggestions?
Old Jul 5, 2010 | 11:31 AM
SVTfocusO3's Avatar
prove_17
check the terminals and see if they are burnt, and if the plastic around them is gone.
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
AAIIIC
Jan 3, 2010 03:41 AM
ruhlin740
Sep 9, 2009 12:22 PM
spinningcain
Jan 25, 2006 09:02 PM
