lower control arm question
Old Oct 29, 2008 | 06:49 PM
weltonb's Avatar
Default lower control arm question
I removed the bolts from the lower control arm on on my '01 v70 and moved the control arm out of its normal position. I can't get it back in position to re-bolt and secure. Do you have any advice?
Old Oct 29, 2008 | 11:33 PM
maximuse34's Avatar
Default RE: lower control arm question
Go sit inside and give it a minute, usually for me it is frustration that causes my biggest problem. Maybe try some sort of lubricating fluid to help it slide in.
Old Oct 30, 2008 | 08:22 AM
It is a pain to get back together. I usually take the axle loose and out of the hub and pull the hub out some so the arm will sit level. Then screw it back in. Then worry about the axle and hub.
Old Oct 30, 2008 | 09:11 AM
weltonb's Avatar
Thx tech. Do you remove or just loosen the axle and nut? Is it diffucult to re-assemble the axle and nut, then? Also, would the sway bar and link be adding to the difficulty in getting the control arm back in place?
Old Oct 30, 2008 | 09:18 AM
I would remove the sway bar link.
The bolt should come out of the axle pretty easy. Then the axle should slide out pretty easy as well.
Make sure you don't lose the rubber part between the axle and hub.
Old Oct 30, 2008 | 10:20 AM
weltonb's Avatar
Thx again for the advice. Will remove the sway bar link and loosen the axle and nut for additional wiggle room. Will let you know how it goes.
Old Oct 30, 2008 | 11:57 AM
maximuse34's Avatar
Sorry, I made am assumption that most of the rest was already apart. Do what what was said and you should be fine.
Old Nov 3, 2008 | 02:00 PM
weltonb's Avatar
Thanks for your advice maximuse34 and tech. All back together. I sincerely appreciate all your good advice.
f8talh8red
May 21, 2009 10:30 AM
etype38
Oct 13, 2008 07:50 PM
sy381
Jul 2, 2008 07:33 AM
tech
Feb 21, 2008 07:52 PM
go2sharks
Feb 25, 2007 12:08 AM
