MmMmMmMm..... Codes....
Old Dec 16, 2008 | 08:24 PM
Platinum52's Avatar
Default MmMmMmMm..... Codes....
So I'm getting codes again. Just got back from autozone:
P0128 - Coolant Temp
P4022 - main catalyst efficiency for bank 1
Now I keep reading that the 2001 V70 has problems with the injectors and it throws catalytic converter codes.... Is P4022 a cat code? Also, I couldn't find anything conclusive on this.
I also read that one code can lead to another, but I don't know which one it threw first!
Thinking about just resetting the codes..... any pointers on this?
Old Dec 16, 2008 | 08:32 PM
Default RE: MmMmMmMm..... Codes....
Yes that is the codes for the injectors.
The coolant temp sensor might be bad making it run rich causing that code as well.
Old Dec 16, 2008 | 10:16 PM
Platinum52's Avatar
So is there any way to determine which injectors are bad or is the name of this game "replace all the dang injectors" ?
Old Dec 17, 2008 | 07:26 AM
Sorry but you will need to replace all of them.
I don't think it is really just one that is bad I think it is a calibration problem with all of them.
Old Dec 17, 2008 | 07:31 AM
HummerGuy's Avatar
Are you sure the code wasn't P0402? I had the same issue you are having a few weeks ago and I replaced the coolant thermostat. That solved the problem.
I had the coolant temp but my catalyst code read "Catalyst below efficiency threshold" or something similar to what you have, but I believe the code was P0402.
Is your engine temp running at mid-way on the gauge all the time? Tech recommended I replace it to try to solve it the easy way and it worked, but he's the expert. I'm just telling you what I did.
My temp was always running cold, especially now in the winter. I'd be lucky if it stayed 1/4 way up. Once I replaced the thermostat, it was running at normal temps, probably for the first time since I had it, and even in Zero degree weather, the temp gauge stays at half-way.
Old Dec 17, 2008 | 12:17 PM
Platinum52's Avatar
Hm, I'm pretty sure that's the code it threw, at least thats the printout he gave me.
Injectors.... sounds fun. Any recomendations on where to buy? May as well do a thermostat while I'm at it, that is the other code it threw.
Old Dec 17, 2008 | 12:36 PM
I haven't done much searching. Not sure of anyone else but the Dealer sells them.
Old Dec 17, 2008 | 12:41 PM
Platinum52's Avatar
Found'em:
http://www.partsgeek.com/catalog/200..._injector.html
117 bucks a pop..... $585 later..... hmm this should be good.
At least the thermostat is only 17 dollars hahaha
Old Dec 17, 2008 | 02:46 PM
TIPSP's Avatar
Got Boost?
Why dont you get them rebuilt? I cant remember the place that did mine.
It should be cheaper than buyingnew ones.
Old Dec 17, 2008 | 03:08 PM
Check here I know someone that was going to get a set for a S70 for like $250.00 for the 5.
You might want to call them the site looks like just to look through.
http://www.fiveomotorsport.com/Injector_SetsSAAB.asp
Old Dec 17, 2008 | 03:27 PM
TIPSP's Avatar
Got Boost?
Thanks tech for the link. Prices look pretty good.I might check them out whenI upgrademy fuel system
Old Dec 17, 2008 | 03:30 PM
ORIGINAL: TIPSP
If you upgrade alot then go for RX7 older ones.
Old Dec 17, 2008 | 03:38 PM
TIPSP's Avatar
Got Boost?
Ok. Thanks
Old Dec 17, 2008 | 09:12 PM
Platinum52's Avatar
Thanks tech - that is good info.
While we're at it, do you happen to have anything you would recommend reading about the injector problem?
Old Dec 17, 2008 | 09:16 PM
No sorry I don't.
Old Dec 17, 2008 | 10:37 PM
TIPSP's Avatar
Got Boost?
This is from a 700/900 FAQ but it should apply tomost injector diagnosis.
http://www.vcoa.org/700-900-faq/Engi...ctor_Diagnosis
Old Dec 18, 2008 | 11:58 AM
  #17
Platinum52's Avatar
Hmm.... Maybe this one is outta my hands. Might have to just drop it off somewhere. To the think tank i go !!!!
gabyman97596
May 14, 2007 09:52 PM
TBoone
Aug 8, 2006 12:52 AM
cranky
Aug 5, 2005 09:46 PM
pitar
Apr 2, 2005 11:37 PM
