My 1st check engine light came on today
![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
1998 V70R AWD. I stopped by autozone and had them read the code. It was for secondary injection or air injection fault (something to that extent) what the heck does that mean? The Autozone dude said it had to do with some kind of vacuum leak??? I don't trust those dudes but I do not know any better so I thought I would ask. It does not run rough or idle funny.
It illuminated shortly after I flipped the air condition on.
Hello, Do you have the exact code? The secondary air injection system might have more than one code which it can generate. The system consists of an air pump (fan in a plastic box), a check valve (the SAS valve which can become stuck) and tubing which connects the two and carries the air to the catalytic converter. Lots of posts about the SAS valve sticking resulting in water accumulating in the fan's box. Kira
after I [posted I went and did a search![Stick Out Tongue](https://volvoforums.com/forum/images/smilies/tongue.gif)
. I am going to check the air pump under the front bumper and then trace and follow the vacuum lines. I have a bunch of vacuum hose (different sizes) in the garage from my turbo Mustang left over so I plan on replacing a lot of the vacuum lines in and around the engine.
Thanks for the laugh. Man, these old cars get those all the time. I usually don't even flinch when I see one. Just read it and reset the thing. I don't even look for a problem unless it comes back on.
This system is so sensative that it pops the CEL every time the car hichups.
I also think it has something to do with the air pump. Look for Vacuum leaks or that stuck valve. My 960 pops that code every once in a while. I think I found a split vac line last time. It was an elbow. Got it from the steeler for $11. Should have gone elsewhere for $3.
Sorry it was P0410 Secondary Air Injection! It's the darn Air Pump if I had to guess. Any way to rig it up where it won't read it and not trigger a light? I do not want to pay $400+ for a new one and it breaks again in 2 years. If you get an upgraded IPD ECU or one of the others can they turn it off?
Hello, I've read that the SAS valve (check valve mounted high at firewall, near the center-line of the car) sticks and allows moisture laden exhaust gases to enter the fan's housing. If it works or if you get a new/junkyard unit then it's advisable to drill a 1/8" hole or two in the bottom of the housing. The fan puts out enough oomph to blow out any moisture and still do it's job. Posters also say to change the SAS valve as that's the cause of the trouble. I don't know if it can be cleaned with solvent or not. Also, the air pump in our cars is shared with Volkswagon and can be had for less. Hope some of that helps. Kira
grndslm
07-02-2012 10:05 PM
oreng
05-11-2011 05:51 PM
