new guy /electric window/lock issues
HI GUYS/GALS;
new to forum,just purchased a 1998 v70 (private owner)
wondering why i got such a good deal.
tried to roll down windows, only drivers side responded from master control
didn't matter whether override switch was ON or OFF
then tried individual controls@corresponding doors
got drivers rear down[:@]won't go back up
tried door locks,@main control,seemed to work
then tried pass. side lock@control [:@]
now doors won't lock.
where should I start troubleshooting?
purchased all switches from this site
http://www.trademotion.com/partlocat...?siteid=213784
listed as new OEM
paid just under $220.00 for all four
will post again when they arrive
listed as new OEM
Yes they are.
Another thing to check is in the door jam the wiring harness from the door is a plug with a turn lock connector. You have to loosen the little torxes screw first then turn the plastic. Check the pins on both sides good and see if one of the terminals slid out.
You still might want to remove the panel and check for power and ground at the motor plug.
