no cooling fan
Old Mar 31, 2011 | 06:51 PM
98ish's Avatar
Default no cooling fan
My98 v70's cooling fan is not turning,I think its the relay.Any other
suggestions?
98ish
Old Mar 31, 2011 | 09:48 PM
Georgeandkira's Avatar
Default my suggestion
Hello, Do a search on that one on ALL the Volvo boards. I've seen posts on the relay you mentioned. Isn't there a temperature sensor on the fan's motor support; right in the air flow? Kira
Old Apr 1, 2011 | 11:42 AM
98ish's Avatar
Default cooling fan problem
If I tap the relay unit,the fan turns, if the sensor was bad you could not get the fan to turn by tapping on the relay.
Thanks for the help.
98ish
rolandt
Oct 16, 2017 12:24 PM
norasaint
Sep 20, 2012 12:53 AM
elouadj
Jun 25, 2008 07:00 PM
vcolper
Nov 1, 2006 10:20 PM
Carbuff
May 26, 2005 12:01 AM
