oil oil everywhere
Old Feb 22, 2010 | 09:07 PM
rgreen4's Avatar
Default oil oil everywhere
98 V70 awd w/180k. Lately I started noticing a oil smell while ideling at a stop, I popped the hood and found thet the entire engine compartment was covered in a thin film of oil and the dipstick was up out of its normal position by 1/2 inch. I thought I solved this problem about 20k miles ago when I replaced all of the oil trap components. Now what? Any ideas?
Old Feb 27, 2010 | 09:53 PM
checksix's Avatar
Any chance you didn't get something hooked up right when you did the previous work? You still have positive pressure in the crank. I'd look for a cracked line etc.
Jerry
Old Feb 28, 2010 | 08:59 AM
rgreen4's Avatar
I did some more investigating into the problem over the weekend and found a split in the rubber connector for the vacuum line from the intake manifold to the PTC valve at the PTC valve. I cleaned the valve and replace the connector and I've been checking the dipstick every time I stop for a while and it hasn't popped up yet. Amazing that something that simple can cause so much trouble.
Can anyone explain how the PTC valve actually works?
Old Feb 28, 2010 | 01:12 PM
ChrisAce's Avatar
I'll bet it is a backup for the PVC valve.
http://autos.yahoo.com/maintain/repa...ques079_1.html
zmontgomery
May 10, 2011 01:37 AM
Winston Niles Rumfoord
Jan 10, 2011 03:41 PM
supernicguy
Jan 22, 2010 06:21 PM
omg007
Dec 5, 2009 11:02 PM
fuzzyyyy
Jul 2, 2009 10:10 PM
