Oil oil everywhere!
Old Apr 27, 2011 | 12:59 AM
zmontgomery's Avatar
Default Oil oil everywhere!
Man, did I screw up today.......took my 960 to the shop because it is leaking a little oil. They replaced something on the PCV system and said that it should help things out. After I left the shop I pulled into o'reilys and got a quart of oil, added a little and then proceeded to drive up the hwy to go to my next stop and get my new set of tires installed. About 3 miles up the road I noticed a bit of smoke behind me as well as the car behind me flashing its lights. I pulled off at the next offramp and had oil smoke surrounding the car. No good. So I opened the hood and realized I forgot to put the oil cap back on after I added the oil. there was 2-3 quarts blown all over the engine compartment as well as the bottom of the car. I can't believe I made such a stupid mistake! Thankfully there was still oil on my dipstick, and everything seemed ok. But still, what a mess! Make sure you check twice after topping off. This mess I have to deal with in the morning is not going to be fun.....
Old Apr 27, 2011 | 10:10 AM
stonepa's Avatar
Have your dealer the engine compartment and underside of the car. I had this done yesterday (as well as a full car detail ) and the car looks like new. Cost me $129 at my Volvo dealership but wow what a difference.
Old Apr 27, 2011 | 03:08 PM
I cleaned everything up this morning with oil eater and paper towels. All is clean now, however my engine is running like absolute crap. I'm really hoping that when I hosed it off something got wet, and just needs to dry out. Because right now the car won't even drive. It idles rough, and chug chug chugs when I put it in gear and try to go. Not good
Old May 9, 2011 | 06:10 PM
Typhoon's Avatar
I'd say you just have some moisture on some electrical connections. Grab some WD40 and spend 15 mins under the bonnet pulling off each electrical connector and giving it a short squirt of the magic spray. Don't forget the spark plug leads!
It'll come good.
Old May 10, 2011 | 01:37 AM
....all is well. I had water in what I think is the throttle position sensor. Dried it out and now she runs like she always has.
Winston Niles Rumfoord
Jan 10, 2011 03:41 PM
rgreen4
Feb 28, 2010 01:12 PM
supernicguy
Jan 22, 2010 06:21 PM
omg007
Dec 5, 2009 11:02 PM
fuzzyyyy
Jul 2, 2009 10:10 PM
