P0237 Turbocharger Boost Sensor A low voltage
Old Jan 27, 2007 | 12:07 PM
Tortuga's Avatar
Default P0237 Turbocharger Boost Sensor A low voltage
Hello,
There seems to be some great advice on this site, so I thought I'd ask for some help. I have a 2001 V70 2.4 T, that has had intermittent check engine lights, which recently has been on constant. I pulled the code and got P0237, Turbocharger Boost Sensor A low voltage. Could anyone help me to diagnose this? The code will not clear, and I REALLY need an inspection!
The car drives and accelerates very well, with some slight occasional surging. I'v read about a boost solenoid which may cause this symptom.
I would really appreciate any advice!
Thank you
-Justin R.
Old Jan 27, 2007 | 12:09 PM
Default RE: P0237 Turbocharger Boost Sensor A low voltage
I would say Boost control soleniod is bad.
Old Jan 27, 2007 | 09:58 PM
Tortuga's Avatar
Sounds like a plan. I've priced the solenoid as low as $38.00. I'd like to do the repair myself, so do you know of a decent manual that can guide me?
Thank you for the quick reply!
Old Jan 28, 2007 | 12:31 AM
The soleniod is on the side of the Air box. Easy to find.
But to answer your quiestion Look on E-bay for a program called VADIS that will give you what you seek.
andrei3333
Oct 2, 2014 05:29 PM
dwwhite
1998-2000 model year V70
Oct 26, 2012 03:30 PM
Jakeman
Jul 6, 2010 07:38 PM
volvo40_2k
Jul 28, 2009 09:18 PM
mick1232
Jun 16, 2009 07:49 PM
