P0301 misfire after driving thru water
Old Oct 11, 2011 | 11:42 AM
79lilred's Avatar
Default P0301 misfire after driving thru water
2001 V70 non-turbo
Drove thru puddle of water just a bit ago. The car immediately started skipping real bad and CHECK ENGINE light started flashing. Went to AutoZone and they read the codes;
P0301 Cylinder 1 Misfire.
Need advice, please!
Old Oct 11, 2011 | 07:00 PM
gdog's Avatar
Most likely the ignition coil for that cyl but that's a guess. Can test it by swapping #1 coil w/another cyl and then see if the misfire code follows the cyl or the coil.
Old Oct 11, 2011 | 07:23 PM
Georgeandkira's Avatar
Hello, gdog speaks true words. Did, by chance, the ignition "problem" dry out with time? How long a drive was it to the auto parts store? Did they clear the code for you? Do you have the tools (very few) and know-how (very easy) to swap a coil? Just for data: How many miles on your 2001? Do you have one of those "bottom splash shields"? Kira
Old Oct 12, 2011 | 07:20 AM
79lilred's Avatar
This is exactly what I did and it was indeed the coil pack. All fixed now. Thanks for the advice!
Was a good 20 min drive home and drivability never changed. Was real concerned as to whether I would make it home. When I pulled the #1 coil pack, no moisture was evident. Hit everything real good with compressed air before swapping #1 & #2 coil packs.
NO. AZ says they are not allowed to clear codes but Advance Auto will.
I am a "gear head" from way back, but my passion has always been Mopar muscle. So, I have more than a "few" tools. This Volvo is my first venture into the world of working on a "new" car that is completely computer controled
It now has around 140K on it ... bought it with ~120K on it.
Splash shield? Uhhh ...... NOPE!
I bought the car 3rd hand and found og owner's name in it. Called her and when I told her I now own her old car, her reply was "Uh-oh! God love you." Seems the car was her teen-age son's and she told me she was tired if him bringing it home after he had run thru, over or into something, so she donated it. I got it from the guy who bought it from the charity.
Old Oct 12, 2011 | 09:19 AM
Hello, I was asking about the splash shield because I was still thinking about the water-shorting-you-out angle. Had I thought more I would've remembered that the plastic bottom shield was an accomodation for the diesel engine cars in Europe. I've been told by posters that no gas Volvo had the shield. You can see the 8 tapped mounting holes for it though. How much was your replacement coil? Kira
Old Oct 12, 2011 | 01:54 PM
79lilred's Avatar
Well considering the splash of the water puddle some how caused the coil to fail, I would think a splash shield would be a really good idea!
Got the coil from AutoZone - made in Germany - $50.99
mikey4040
Feb 28, 2021 04:34 PM
nmikmik
Apr 2, 2015 12:37 AM
ssteak1
Jun 14, 2012 08:45 PM
CimpleSypher
Dec 13, 2010 01:56 PM
skatermattc2
Sep 2, 2010 02:17 AM
