Pinging / Oxygen Sensor
Old Nov 21, 2010 | 06:46 AM
Richard Lane's Avatar
Default Pinging / Oxygen Sensor
2002 V70 2.4L - I have code 2110 "Front Heater O2 Sensor Preheating Signal" and slight pinging/knocking (sounds like a deisel car) when engine is under load. Q1: Will replacing the O2 sensor fix this? Q2: Will an after marked O2 sensor be OK (cheaper, I assume)?
Old Nov 21, 2010 | 07:35 AM
I would replace the sensor with a Bosch only. These cars do not like cheap O2 senors.
Then I would run a good injector cleaner through the system and see from there.
I like the Techron for the injector cleaner. You just dump it into the fuel tank and go.
brick'n it
Dec 30, 2012 02:10 PM
tresjolie2
Nov 7, 2010 07:33 AM
1991_240wagon
Aug 6, 2009 07:22 PM
trlwys
May 7, 2008 05:57 AM
jktiffin
Jul 24, 2006 08:32 PM
