Problem releasing transmission out of park
Car is a 1998 V70 FWD with 175K miles. The problem seems to be getting worse. When starting the car, I'm unable to move the automatic transmission from park. The shifter is well worn with a crack in the area of the release button on the shifter. I turn the car off and push the lock out button and it seems to be OK.
My daughter is now driving the car and I'm concerned about her getting stuck someplace.
I'm just trying to get an idea of how expensive it will be to fix the problem. Any thoughts or suggestions appreciated.
Jim
Jim
I hope that it is only that worn shifter, my 98 V70 had same simptom though my shifter looks nice and has no imperfections, however, sometimes it was hard to move shifter into drive, Today the V70 has seen her last day.
no drive at all. but the shifter is moving through all drives, some grinding noise when I put into drive. No reverse and no drive. but what is more facinating is that when I put the car in park, you can still push it and it moves just as in neutral.
I hope yours will not end this way. I scan but there is no code in the scanner.
stunna7516
08-16-2017 02:00 AM
