Problems with V70. Check engine lights
Old Feb 6, 2011 | 02:18 PM
njwandrew's Avatar
Default Problems with V70. Check engine lights
i got an OBD2 code: P0763 i was wondering if anyone could help me locate the shift solenoid and if it is possible to repair it!
the other i got: P1618 it says there is fault in the electronic throttle system, fault in the lead
COULD SOME ONE HELP ME PLEASE!! ASAP
THANKS
Old Feb 6, 2011 | 02:30 PM
Vilenica's Avatar
I dont have an answer for you but Im sure you will get one around here, I just have a suggestion after reading your post if your going to diy with things like that - get a haynes or chiltons on your vehicle, those books might cover those components or probaly atleast offer an exploded view so you can get an idea where they are at.
Old Feb 12, 2011 | 05:45 PM
nelsonent1's Avatar
Default What year, make, model?
Some of the 1618 codes on my car were from the ABS unit under the master brake cylinder. There are other codes that came up too like P1633 P0722 and a lot of random warning lights on the dash
Old Feb 13, 2011 | 03:12 AM
v70man's Avatar
OH! Here we go again! the ETS light problem... this is a common fault on the v70, the ELECTONIC THROTTLE SYSTEM is so sensitive that it becomes a problem... you don't mention if the car has gone into limp mode? if it hasn't don't worry the mechinism requires a good clean out, mine does it occasionaly mainly after a long fast journey.... new ones are a small fortune and volvo made only.
Old Feb 13, 2011 | 06:51 AM
Georgeandkira's Avatar
Default What year
Hello njwandrew, What year is your V70 and how many miles are on it? IF your ETM is bad there's a company which rebuilds them for less than Volvo charges for a new one. XeMODeX is the name of the Canadian company. Vic Rocha rebuilds ABS units if that's your other problem. Kira
Old Mar 2, 2011 | 01:39 PM
Edward R's Avatar
Default Message Panel Quit
On my V70 the message panel shows Alarm Needs Service. it came on once a week,It showed yesterday ,after that the panel stopped working..
eg Door open. the panel lights but no messages,this morning when I entered the car in our heated garage it worked,When I left 12c. to the -1
outside, it quit again.Had the car washed yesterday could that have soaked the alarm modum in the RF.fender well and have caused this problem??Ed
spankey
Dec 14, 2012 01:25 PM
Vpstan
Sep 22, 2010 10:31 PM
sadie41
Sep 1, 2009 07:10 AM
moetan
Jul 31, 2007 09:47 PM
