removing kick panel to replace blower
Old Jul 5, 2006 | 06:21 PM
gwoodall's Avatar
Default removing kick panel to replace blower
I will need to replace the blower motor soon and I can easily remove the glove box but can't for the life of me find the torx screws that remove the lower kick panel. I think it is different on my 2000 v70 than on an 850, which is covered in the Haynes Manual. Also, any trick to removing the glove box hinges?
thanks
Gene
Old Jul 5, 2006 | 09:03 PM
Default RE: removing kick panel to replace blower
The Hindges there is a notch in the door use a small pick in the hole to release.
Once the glove box insert is out you will see 2 or 3 screws holding the kick panel on.
Old Jul 7, 2006 | 03:49 PM
gwoodall's Avatar
Thanks! Found them. I can also see them throiugh the partially opened glove box door where they hold the kick panel tabs. Different setup than the 850.
Thanks Again
jmallie
Sep 17, 2009 09:47 AM
rp850
Oct 22, 2006 03:34 AM
jc740T
Feb 6, 2005 09:00 PM
