Resetting service message on 02 V70?
Old May 31, 2010 | 09:26 AM
ShawnM 02 V70's Avatar
Default Resetting service message on 02 V70?
Hi all! I tried the reset proccedure for resetting the service message that apparantly worked for artgirl who has an 06 V70, and it did not work on my 02. Can anyone help on resetting the message on an 02 V70. Unfortunately my code reader does not reset this message either which was a little disappointing.
Thanks, Shawn
Old Jun 1, 2010 | 11:29 AM
SVTfocusO3's Avatar
These years are tricky sometimes.
Follow all the steps you did before, but do not look for any flashing symbols, as soon as you hold the trip button in POS 2, count to ten and proceed as usual, letting go, turn key off.
let me know if this works.
Old Jun 3, 2010 | 10:16 PM
Thanks I will try that in the morning!
Shawn
Old Jun 9, 2010 | 11:14 AM
No luck with this new proceedure! I guess I will have to live with service reminder until the next trip to the shop.
Thanks for the suggestions,
Shawn
Old Jun 13, 2010 | 12:39 AM
SVTfocusO3's Avatar
Shawn, one more thing, and READ THIS CAREFULLY!!!!!!!!!!
Let me give you another tip, if you have miles in the trip meter, you know the one you can reset, right below the odometer. If you perform this procedure of resetting the maintenance light, the miles usually go to 000.0, because your holding the trip button!!!
Now, if you pay close attention during the reset procedure, this 000.0, it will reappear within a certain amount of time, with the miles you had on there before, and when it does, let go of the trip button and turn the key off, IMMEDIATELY!!!
Let me know how it goes, otherwise dealer will do it for you, it may need software.
Old Jun 18, 2010 | 10:48 PM
Default No go!
Thanks for the suggestion but this did not work either.
Shawn
barontarl
Dec 1, 2010 09:35 PM
PAPPYBALL
Apr 16, 2009 03:57 PM
whome
Oct 24, 2008 05:17 PM
master_pre
Aug 21, 2006 09:01 AM
bongo240
Apr 1, 2004 06:33 PM
