Right motor mount
Old Jul 23, 2011 | 08:45 AM
wondering's Avatar
Default Right motor mount
My car had a flat tire so I took it in for repair. Was told the right motor mount needs to be replaced. How extensive a job is this? How important is it? Does it need to be done right away? Is it a result of all the potholes in the raids today? Thanks!
Old Jul 23, 2011 | 09:48 AM
Volvos rock's Avatar
It is not from any pothole, normal wear and tear. It is relatively easy to replace, support engine, un bolt, raise engine R&R, lower engine, tighten bolts. If this one is shot your two tourqe mounts are probably shot (upper and lower) along with your strut bar bushings.
Old Jul 23, 2011 | 10:07 AM
wondering's Avatar
thanks - they quoted me $427 - with one and one-half hours labor and the motor mount. seems like a lot to me, what do you think and how soon should I gwt this done?
Old Jul 23, 2011 | 06:17 PM
What year is your car? Here are some instructions I posted.
Motor mount, right side, Volvo S70, replacement instructions
Don't hesitate checking the 850 DIY sticky if you have a pre 2001 V70.
Old Jul 23, 2011 | 08:39 PM
quietlymknnoise's Avatar
I tried an aftermarket right mount and it failed in less than 6mos. I switched to OEM Volvo no problems.
Old Jul 24, 2011 | 06:05 AM
wondering's Avatar
Default Car is a
2003 v70
Old Jul 24, 2011 | 08:10 AM
That seems high for 1 motor mount. Mount is available from FCP for $60. I did this mount, upper and lower tourque mounts and strut bar bushings for less than half of that. Where are you located?
Old Jul 24, 2011 | 01:00 PM
I'll check our mount on the S70 and see if it's still holding up.
OldVolvoGuy
May 7, 2015 01:31 PM
tuner4life
Apr 27, 2012 06:41 PM
Hugh G Rection
Jul 1, 2007 02:42 PM
