Steering Noise inside cabin !!
Old Nov 15, 2006 | 05:18 AM
v70 2.4t's Avatar
Default Steering Noise inside cabin !!
Hi, Had the car in for timing belt, all cam seals, crankshaft seal, brake booster.
Car is back, sounds like a normal car now...only one problem, the steering makes a
noise like turning you wheels on a painted garage floor, but its on the inside of the cabin.
under the dash..could something have been shifted while disconnecting the pedal from the booster??
V70 2.4t
Old Nov 15, 2006 | 01:06 PM
S70driver's Avatar
Default RE: Steering Noise inside cabin !!
Is it a moaning or groaning sound?
Does it only really happen when you turn the wheel left or right?
What year is your Volvo?
Check out this, this may be your answer. Steering Bearing Issue
Old Nov 15, 2006 | 09:03 PM
They might not have seated the bearing where the rack goes through the body.
ABVO850
Feb 29, 2012 07:06 PM
allenzachary
Dec 8, 2011 10:20 AM
tnburban
Jul 8, 2010 01:26 AM
pxl8ed
Nov 3, 2009 11:31 AM
wheelsup
Sep 10, 2007 06:45 PM
