TD04HL-13G turbocharger
I pulled the turbo from my v70xc. Thats what it is td04hl-13g. So, what can I use to replace it? Will other variants of tdo4h fit? How about a td05 15g?
If nobody here can help, can you refer me to a knowledge base?
Reason I ask what else fits is because I am having a hard time finding that exact turbo. Found a td04hl 13gmhi,,, same? If not, differences???
So, I went to the DSm forums and asked around,, sinse these are mitsubishi turbos. A wealth of information there. Anybody else looking for real usable information about turbos? I recommend you do the same, or turbobricks...
Just to finish this off,, I selected a td04hl -16t as a replacement for my 13g. Its basicly just a factory upgrade. Holds more pressure, and flows more volume. Same center section so oil and coolant lines match right up.
Hopefully this will be of some help to the next person.
jessica
Jul 6, 2010 12:53 AM
13g, 15t, catapilar, charger, hl13g, info, mitsubishi, replace, specifications, td04, td04hl, td04hl13g, turbo, turbocharger, volvo
