Top engine mounting refitting?
Old Jan 20, 2009 | 10:09 AM
Paudman's Avatar
Default Top engine mounting refitting?
My 2001 V70 T5 has a very annoying thumping from the underside when going over bumps which I think is the exhaust; I replaced the centre bracket but it made no difference. At rest I can pull on the exhaust from below and it does not move at all, so I suspect something else is assisting the movement.
The top engine mount rubber has fractured so I've bought a replacement, plus two new brackets for the torsion bar to which it attaches, as this rattles as well. I think maybe the engine is moving which allows the exhaust to drop and strike the crossmember behind the centre box. I'll be fitting the new mounting myself but: on fitting, do I need to prop / jack / support the engine? I'm wondering if the engine at rest is in the correct position and I just tighten up the bolts where they go through the slotted holes on the brackets, or will it drop backwards when the top mounting is removed and so needs to be pushed or pulled back into the correct position before tightening?
Any tips for correct fitting would be appreciated!
Old Jan 20, 2009 | 10:12 AM
V70Pinner's Avatar
Default RE: Top engine mounting refitting?
I'm not sure if your car is an AWD model but i had a similar thing happening from the driveshaft, especially under acceleration in slow tight turns.
Good Luck
Jeff
Old Jan 20, 2009 | 10:31 AM
Paudman's Avatar
It's not AWD Jeff, so I suspect the exhaust flexing as the engine moves during driving...
Old Jan 20, 2009 | 10:59 AM
The top mount just basically drops in.
Also check the spring seats for the front end.
Also check the lower torque rod(mount) from the transmission to the subframe.
Old Jan 23, 2009 | 08:25 AM
Paudman's Avatar
Just replaced the mounting (twice - first mounting was rubbish quality) but I was amazed at the amount of movement in the torsion bar to which the top mounting attached - so much so that I bought new mountings for this too.
I've just fitted both and the movement of the bolts in these is still amazing. The entire bar moves backwards and forwards in the bushes, with the inner bushes flexing quite dramatically in the housing. Is this meant to happen?
Old Jan 23, 2009 | 08:38 AM
Yes it is supposed to move that much.
tech
Oct 10, 2017 09:43 AM
pacificnw2011
Sep 5, 2010 07:42 PM
pow
Apr 26, 2010 08:05 AM
1997 GA16DE
Apr 24, 2005 04:07 PM
krujo
Feb 11, 2005 01:36 PM
