TRACS/ABS Question
Old Mar 29, 2006 | 10:20 PM
rmmagow's Avatar
Default TRACS/ABS Question
I have a 1998 V70R AWD w/Automatic tramsmission. There is a TRACS button on the dash. I am pretty sure the car is supposed to have traction control. I've pulled the ABS unit and see only 7 solenoids which I believe is only ABS. I am thinking that this unit was put in due to the original failing. The ABS unit itself has just the 7 posts to go into the computer. Was traction control an option on the V70R AWD? or is this in fact the right unit for the car? Anyway I can determine if it was supposed to have TRACS and maybe had a regular ABS system swapped in?
Thanks for any and all advice.
Old Mar 29, 2006 | 10:28 PM
rmmagow's Avatar
Default RE: TRACS/ABS Question
Never mind. I was able to make out "CONTROL UNIT TRACS 2/4WD" on the control unit itself. Off for a rebuild!
Phil 850
May 31, 2013 06:29 PM
paulh
Jan 30, 2008 08:22 PM
Buck
Aug 11, 2006 12:56 AM
rpm48
Mar 17, 2006 08:50 PM
vwown3d
Aug 20, 2005 03:01 PM
