Trans issue??
Old Mar 28, 2006 | 04:36 PM
Moparman's Avatar
Default Trans issue??
02 V70 2.4T
About 75% of the time, when going from any gear, to drive, it lurches into gear very hard. You can feel a slight bump, and then a pause, then quite a hard hurch as it goes in. This isn't the neutral/stop shift, that has been programmed out as far as I can tell, its never done it since we had it. Dealer has done a reflash,flush, and readaption, its no better. Software update did make it shift through the gears nicer, but thats it. Now the response is, "its normal". There is no way its normal, hitting as hard as it does,esp when it doesn't do it all the time. From the searching I have done, this looks like a valve body issue? All other shifts are fine, up and down, just when changing from P,R,or N to drive it does this. Allthough sometimes if cold outside, it does hang in first a bit, gotta let off , then its fine. Any ideas??
Old Mar 28, 2006 | 09:29 PM
Default RE: Trans issue??
Either they didn't adapt it correctly after the software install or the Valve body is going out.
Old Mar 28, 2006 | 10:32 PM
Moparman's Avatar
Well it doesn't act any differnt after the software or adaption, so i'm guessing VB. This a common enough issue they should know about it?
Old Mar 28, 2006 | 10:36 PM
Volvo Knows they have Transmission problems.
They will sell you a tranny instead of doing the Valve body.
Old Mar 29, 2006 | 10:54 AM
Moparman's Avatar
They won't sell be anything, got lots of warr. left, just gotta get them to admit there is a problem. Guess I'm gonna have to get ugly! Thanks
Old Mar 29, 2006 | 06:49 PM
BEAT IT TILL IT BREAKS!!!
Old Mar 30, 2006 | 01:16 PM
Moparman's Avatar
Thats kind of what they said" you still have lots of warr. left....." Nice attitude. Just very anoying to drive it like this .............I'm gonna go have a chat with them. [sm=badbadbad.gif]
Old Mar 31, 2006 | 09:57 PM
Let us know how it goes.
Old Jun 11, 2006 | 11:43 PM
Moparman's Avatar
Well FINALLY got it fixed. Selling dealer wouldn't do anything, said it was "normal"...........took it to a differnt dealer, took them a MONTH, yes they had the car a MONTH, but finally put a brand new trans in, replaced a door latch that was bad, and seatbelt that kept hanging up. Hope this ends the problems for awhile. Can't even feel it go into gear now, so much for smashing into gear being "normal"
Old Jun 12, 2006 | 01:07 AM
Thank god you got it fixed.
Glad they also fixed the other things for you.
Old Jun 12, 2006 | 04:41 AM
v70 2.4t's Avatar
Moparman,
If you dont mind can you tell us the final repair bill??
v70 2.4t
Old Jun 13, 2006 | 12:17 AM
Moparman's Avatar
$50 deductable .............looks like it was about a 5k job, i was peakin at the paperwork, while the advisor was doing something else.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
