tube missing..disconnected..what is it and is it bad?
Old Nov 20, 2010 | 12:21 PM
chef's Avatar
Default tube missing..disconnected..what is it and is it bad?
Hey guys ,i decided to take a peek under the hood today (there was a disturbance in the force!)...so i checked my oil and it was okay, i took the light and started looking. I noticed a tube that had disconnected itself and seems to be missing a "joint" section....if i'm looking at the engine, at the oil filler cap, to the left of it right where the spark plug cover is, there is a plastic tube that starts there goes in between the intake manifold and is supposed to go into a box? is this the pcv box? well from the manifold , it is disconnected and seems to be missing a piece..here is a pic of the tube coming down:
Here is a pic of the tube where it's disconnected..i was looking around and can't find the missing piece.
is this really bad for the engine and other componencts? is it a big job to replace the piece?
thanks
fabs
Old Nov 20, 2010 | 01:30 PM
That is the hose from the vent box. I would get it fixed soon.
The engine vent system is not working properly now.
Old Nov 20, 2010 | 01:34 PM
chef's Avatar
Hey Tech, long time no see..how are you?
thanks for replying...from pics that i've seen, isn't this long tube supposed to be one piece? it seems like a section is missing thoug?h? does the intake manifold need to be taken off? i hope not, i can fit my hand from behind it, maybe it's an easy fix? is there a valve in the missing place or just tubing?
thanks
fabs
Old Nov 20, 2010 | 01:37 PM
The older cars used to be one bog hose. The newer style hoses they put like a flex section in there which over time hardens and breaks. Yes you need to remove the intake manifold to replace it.
I am hanging in there lately just really busy.
Old Nov 20, 2010 | 01:49 PM
chef's Avatar
noooooo i really need to take off the manifold? i can get my hand back there and re attach it...how does this connecting piece attach, clamps on both ends?
i don't wanna have to shell out big bucks to remove manifold for just a small piece..
fabs
Old Nov 20, 2010 | 01:54 PM
Yes there is a clamp at the vent box and one under the top spark plug cover.
You will need to buy a new hose to.
Old Nov 20, 2010 | 02:07 PM
chef's Avatar
I'm a little confused though...on the tube i have i'm missing that FLEX section, but when i looked at the replacement part on IPD, it's one solid long piece of tube...what this the newer version of the tube? can i just buy the FLEX piece that's missing or a whole new tube?
fabs
Florida runner
Apr 4, 2015 08:32 AM
james thomas
May 26, 2010 10:59 AM
vjaneczko
May 3, 2010 07:35 PM
CyDetrakD
Jan 21, 2009 11:58 AM
KubilayK
Nov 24, 2008 07:57 AM
