V70 auto gear stick lights
Old Dec 7, 2008 | 01:10 PM
jak.46's Avatar
Default V70 auto gear stick lights
Help please how do i change the lights inan automatic gear lever to show which poistion the lever is in when its dark.
Old Dec 8, 2008 | 07:43 AM
Default RE: V70 auto gear stick lights
You need to remove the center console to replace it.
Under the arm rest lid in the bottom of the cubby there is a cover hiding 2 screws. Remove the 2 screws. Then with the lid still open slide the black panel around the e-brake handle towards the drivers seat and slide it off the handle. Then you will see 2 plugs. Unplug them and you can lift the console out. Lift the rear up first and slide it back and out.
m.olennick
May 3, 2012 03:41 PM
winston901
Mar 11, 2012 12:51 AM
tupapison
Feb 26, 2006 02:10 AM
Qamar
Oct 14, 2005 06:22 PM
Qamar
Aug 27, 2005 07:25 AM
