v70 starting problems
Old Feb 10, 2006 | 03:20 PM
raymondo's Avatar
Default v70 starting problems
Volvo v70 2001 intermittiant fault, car starts then stalls,restart lumpy,after increasing revs for 10 secs then will idle ok.
temp or standing time bear no patten to problem. Did have radio replaced with after market unit,car runs fine, no warnings or messages
any thoughts,thanks in advance Raymondo
Old Feb 11, 2006 | 05:53 PM
Default RE: v70 starting problems
A couple of things have you had the throttle body cleaned lately?
Did the dealer install software to remove the factory radio?
Old Feb 11, 2006 | 06:14 PM
raymondo's Avatar
no the throttle body has not been cleaned or the comp told the radio has been replaced, could the comp be causing the idle fault? thanks tech
Old Feb 11, 2006 | 08:24 PM
Anything is possible. The car is on a network. If one of the computers goes out it could take out more of them.
To have the software installed to remove the radio should cost about $30.00 for the software and between 1/2 to 1 hour labor. It should only be 1/2 hour though.
Nontechie
Oct 24, 2008 11:55 AM
H20Gguy
Sep 17, 2008 12:58 AM
mparker
Aug 31, 2008 08:02 AM
jghalvorsen
Oct 6, 2007 10:28 PM
audioblob
Feb 28, 2007 09:02 PM
