V70R Radio Codes
V70R Radio Codes
My radio is an SC-910. The dealer gave me the code via the VIN number. I get a CODE display when the car is turned on, I enter the code, is asks me to re-enter the cade. I re-enter the code and the display goes to SYSTEM OFF. The battery in the car is quite weak which is what triggered this problem from the begining. Should I re-charge the battery before trying again with the code? Is there a special way to enter the code or just push the buttons?
When the dealer pulled the info for my car I also got a VGLA Remote Key PIN and a VGLA Locktype PIN. will these be of use in trying to find a remote for the car?
Thanks for any info.
RE: V70R Radio Codes
You locked the radio. It will need to sit for atleast 2 hours to reset with the key in the 1st position and radio on.
Then have them get you the code from the Radio serial#
When you have the proper 4 digit code enter it and it will come on.
The other codes they gave you won't help you at all. They Dealer uses them to program the remote.
timer00
03-02-2009 10:21 PM
gabyman97596
05-14-2007 09:52 PM
