Very Annoying Rear Squeak
Old Jul 26, 2021 | 02:24 AM
gorbag's Avatar
Default Very Annoying Rear Squeak
Hi,
New here after buying my first V70. A 2013 D4 SE LUX which is brilliant apart from an annoying squeak that started a couple of weeks after I took ownership.
At first I was almost certain the noise was coming from the rear seat back rest catches as it's an identical high pitched metal on metal chirping that I have had on other cars and that was the cause. So I greased the catches and latches with lithium grease but it made no difference. I removed the rear seat itself and made sure there was no metal to metal contact there. I've removed everything from the boot and still it squeaks.
Thing is it isn't consistent. You can drive all day and it won't squeak till you go over a bump. Then it starts and won't go away. I discovered one day it seemed to stop when I braked so I had new discs and pads fitted, which needed done anyway, thinking maybe the pads were jumping about over bumps. Still squeaks! I've run out of things to grease, including the hatch catch and hinges, doors...... and am now thinking it may be the strut mounts or something suspension related. Seems to be the rear near side and is definitely worse under load. I've had creaks in suspension before but not this high pitched chirping that sounds internal.
Any help or suggestion would be greatly appreciated and sorry if this a known issue and has been discussed already somewhere.
Cheers
Old Jul 26, 2021 | 10:40 AM
I'd inspect the rear springs. its quite possible one of the springs broke off an end causing some metal on metal.
Old Oct 25, 2021 | 12:30 PM
mike91711's Avatar
Originally Posted by gorbag
Hi,
Cheers
I have 2009 V70 which I really like. However, it has been making thumping sounds when I go over dips at intersections. I had the dealer replace the front struts and it still makes that noise. I hope it is not the motor mounts.
Old Oct 25, 2021 | 02:38 PM
did the dealer inspect other suspension / chassis components while doing the struts. Could be the exhaust system (my first bet), motor mounts (does the sound change with/without power?), subframe bushings, sway bar bushings, control arm bushing (does the car feel like it goes in/out of alignment?) etc? Does it sound different turning left or right vs going straight? Have you looked around for anything else like the battery tie down?
dougburgy
Sep 17, 2016 09:28 AM
boldtu
Feb 1, 2011 10:56 PM
boldtu
Sep 3, 2010 01:56 AM
garthpro
Jun 14, 2010 06:39 AM
dtsol
May 11, 2009 09:47 AM
