vibration at high speeds? help
I got 2 problems:
1. my 98 T5 Turbo wants to vibrate a bit above 60mph. what's up with that?
2. I'm also getting "jolted" whenever I hit a bump or pothole . I bounced the car up and down but the shocks don't seem to be bad. the car does not "bounce" after I push down on it. I don't "think" I need any shocks, but not sure. I changed the shocks at maybe 90,000 it now has 120,000 mile on it. so it appears obvious I might need them. but....
Any help is appreciated. thanks.
ORIGINAL: 98T5
I don't know. I never changed them since I've had the car. Only the rear shocks. but the struts don't feeel bad. how are they suppose to feel when the y go bad?
ORIGINAL: JimKW
Could be a bent wheel. What kind of struts did you use?
If your mechanic says that everything is tight, I would check the wheels. You could have had a wheel weight come off, hit a large pot hole and bent a wheel, etc.
ORIGINAL: JimKW
Aren't wheel balance problems under 60 mph though? Does the vibration go away at higher speed or does it get worse? Could be bad tires too. I have had cases where the tires looked great but were crap and the wheels were fine.
Struts/shocks control the springs. Without a strut/shock or with a blown strut/shockyour spring will be free to bounce around and do as it likes, which is very common on cars that are lowered with stock struts/shocks where the spring rates are far too high for the strut to control (gives that crappy bouncy ride feeling.)
but what aobut the "jolting" I get when I hit a bump or pothole. it makes me think the sturts/shocks are actually bad. weird ride.
when I'm out on the highway at 70-80mph it's smooth but with sutble vibration. no pulling to either side.
when I'm city driving, I can fell every bump or pothole. it's uncomfortable at times.
ORIGINAL: JimKW
The following 2 users liked this post by BigV592:
fred in florida (05-17-2023),
Naffy03 (06-27-2022)
oragame
07-21-2005 11:42 PM
