Weird Electrical Problems
Old Mar 20, 2022 | 01:05 PM
02 v70's Avatar
Question Weird Electrical Problems
The dash gauges work intermittently. The ABS, check engine, and other warning lights are constantly illuminated. The text display says brake failure all the time, but the brakes seem to work fine. Also, the air blower or heating and air conditioning do not work. Cruise control also does not work.
My dad said this started happening after he took it to a mechanic.
How would I fix this problem?
Old Mar 20, 2022 | 04:03 PM
The first step would be to scan the car with a compatible scanner that can talk to all the control units. After that formulate a reasonable, rational diagnostic path. You might simply have a bad DIM (drivers instrument module, the instrument cluster). It would however be unusual for the DIM to affect the CCM (climate control module) But a scan would hopefully point you in the right direction. A bad instrument cluster is not a unusual repair for your car.
A company such as xemodex can provide repairs or plug and play replacements for DIMs.
https://xemodex.com/us/available-ser...ment-clusters/
Old Mar 20, 2022 | 06:25 PM
02 v70's Avatar
Question
I checked the fuses, and a lot of them had the wrong amperage. I replaced the one for the blower motor with the correct amperage, and it now works. Also, the one that is for the ECM, Centeral electronic module, and airbags (its one fuse for all of them) was a 30amp instead of 10.
jscruggs2003
Aug 29, 2011 09:18 PM
macropis
Oct 24, 2010 10:53 AM
n5554t
Aug 16, 2009 01:12 PM
Teachrz
Oct 13, 2008 08:44 AM
ps8611
May 2, 2006 09:18 PM
